Ring gasket- Groove one side only
I'm reviewing the design of a pressure vessel that uses a ring type gasket. The gasket is neoprene instead of metallic. There is a gasket groove on only one of the flange faces. The gasket seals against a flat face on the other side.
Does anyone know what a design like this might be based on?
RE: Ring gasket- Groove one side only
https://www.parker.com/literature/ORD%205700%20Par...
The condition I have is the face seal O-ring in the reference you sent. I'll look through that and see if it answers my questions.
