Attributes in PMI note
I have an assembly with several exploded views and several assembly arrangements. I want to create a note in PMI to display the name of the current assembly arrangement and the name of the current exploded view. Where do I find those names as variables so that I can put them in PMI?
NX 9.0 TC 10
RE: Attributes in PMI note
Without writing some sort of utility using NX Open or Knowledge Fusion, I know of no where that you can find that sort of data in a form where you could link it to a PMI or Drafting note.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I can get the information by clicking Menu > Information > Assemblies > Explosion and picking on of the explosions. The information window has what I want in it. Are the circled items generated from system variables that are accessible?
The info window has a line:
Explosion name Part1
At the bottom is a line:
This explosion is based upon assembly arrangement Part1 Assm.
Attached is a screen shot of the info window.
NX 9.0 TC 10
Yes, I know that the data you're looking for can be seen in a listing window, but there is no automated way, unless you develop a custom application as I mentioned above, to extract and then link those values to either an attribute or a Drafting/PMI note.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
