Seismic application on Monograph 27
I was asked to design shaft walls using Monograph No. 27. My plan checker requires me to add seismic. Can I use the reaction coefficients for my computed seismic force?
RE: Seismic application on Monograph 27
Are we talking tunnels?
Yes the vertical air shaft is for a tunnel with soil assumed in level with top of wall for easy application of tables. Is Load IX a fit for applying seismic? Although seismic should be in plane....
This sounds like a question for your plan checker.... It could be that i have no idea what you are talking about or it could be a broken coffee machine today.
