ACI 318-11 Special SWAY FRAM
Hi
In the code this clause is not totally clear R21.5.4.2
when he calculate MPl, which combinations he used is it the envelope combinations for all cases(gravity +lateral) or envelope for earthquake combinations only
and regarding wu he will take only the combinations for gravity load only or envelop of gravity load or what exactly?
I need to clarify this, to do proper calculations
Thank you
Thank you
RE: ACI 318-11 Special SWAY FRAM
Mpr is calculated probably member capacity. It would be calculated based on the cross sectional properties and is not directly related to applied load.
I believe that the rationale presented would apply to any load combination involving seismic loads.
