Shell thermal analysis -> Stress Analysis
What is the best way to do a shell thermal analysis, and then to load the temperatures for a stress analysis?
I have tried doing a coupled simulation, and that worked, but what if you want to do it separately?
I have tried doing a thermal analysis and tried loading the output .odb file as a temperature input into the stress analysis. This never seems to work properly as only one section point gets assigned and the rest don't so the temperatures are incorrect.
I have succesfully been able to do a thermal analysis, then open up my stress analysis and create a Analytical Field with an ODB mesh from viewport. This seems to pick up my NT11 temperatures and assigns them to my stress mesh. Seems to work, but is tedious...
Any tips or links?
RE: Shell thermal analysis -> Stress Analysis
For shell models with sequentially coupled thermal-stress I have always had to create the shell section in the Property module with the temperature variation option changed from "linear through thickness" to "Piecewise linear over" and put 5 in the values box, to end up with NT11, NT12, NT13, NT14 and NT15 being the 5 temperature points through the thickness. This is in the advanced tab on the edit section dialogue when creating a shell section. Do this in both the thermal model and the stress model.
