Aluminum Magna-Lok fatigue
Hi all.
Do any of you use Alcoa-Huck Magna-Lok rivets in aluminum plate? Do you have any issues with blind side loosening because of the bulb shape providing virtually no blind side footprint? Is there a recommended blind side chamfer that could help this?
Plate thickness: 3/16
5083 aluminum
Rivet diameters: 5/16 and 3/8 (mostly due to existing hole sizes and grip lengths)
Any help would be appreciated...
tg
5083 aluminum
tg
RE: Aluminum Magna-Lok fatigue
Are you sure you're not thinking of the Magna-Bulb? That one has more of a flat blind side print and resists pull-out better. For the Magna-Lok, I am concerned with high local stresses right at the blind side hole edge and potential loosening/water-tightness issues. I have never given this a second thought with other Hucks, such as C6L, BOM, or others. The Magna-Lok is more like a heavy-duty pop-rivet, which I have used in steel, but rarely in aluminum.
Are there any other ideas out there for a blind fastener, in aluminum, that leaves a round or truss head on the near side and has a decent blind side footprint?
tg
Great suggestions - these actually work for my application, although they only go up to 0.25 diameter. I now just need to convince my client that aesthetically, the smaller rivet heads (than existing adjacent ones) will be OK.
Thanks!
tg
No, I was looking at Alcoa-Huck Magna-Loks.
