LED vs. Laser Light Source / OM4 Multi Mode Fiber Optic Cable Attenuation
I have an application involving a 1,200 foot run of OM4 laser optimized 50/125 um multi mode fiber optic cable. I have a new device that needs to communicate over this fiber link, but it only comes with a LED light source. Specs for new device are:
Light Source: LED
Data Rate: 100 Mbps
Wavelength: 1300 nm
Multimode: 62.5 um
Optical Budget: 11 dBm
Max. Distance: 2 km
Since I will be using 50 um multi mode cable with a LED light source, how do I determine the maximum distance based on above specs?
I have attenuation data for both 50/125 and 62.5/125 um multi mode cable, but I cannot figure out detailed impact of using LED vs. Laser light source.
Light Source: LED
Data Rate: 100 Mbps
Wavelength: 1300 nm
Multimode: 62.5 um
Max. Distance: 2 km
RE: LED vs. Laser Light Source / OM4 Multi Mode Fiber Optic Cable Attenuation
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
