What are the tests to dtermine f 'c for a concrete fnd. or pier - How we can chk corrosion in the co
Two questions:
1- What are the tests to dtermine f 'c for a concrete fnd. or pier ?
2- How can we chk that corrosion on the projection of anchor bolt has gone to the embeded part of anchor bolt or not?
Thank you
RE: What are the tests to dtermine f 'c for a concrete fnd. or pier - How we can chk corrosion in the co
For the corroded anchor, you might have to chip out the concrete to see. Again, probably calling a local testing agency would be your best bet. You'll get lots of options here from people around the world, but if a local company isn't available to perform the testing then you're out of luck.
What are typical methods or tests for above questions? I thought these very typical problems !
1. Compression test of a core sample.
2. Schmidt Hammer Test (not very accurate).
To determine extent of rust, dig down and inspect.
BA
