High Amperage Boost Converter Design
This popular boost converter design. Is this an acceptable design to boost 48V up to 170V with 100 amp output? Or, is there a more accepted design for this type to DC step up?
RE: High Amperage Boost Converter Design
Crikey.
Here are just a few suggestions for study: A single full-bridge using one of those Infineon water-cooled bridge modules, Multiple SMPS all tied together such as: multiple full bridge, half bridge, or auto transformers.
Darrell Hambley P.E.
SENTEK Engineering, LLC
Besides a multiphase/interleaved boost (and likely 8+ phases) I would consider using multiple 2-switch forward converters or a single current-mode push-pull. The latter two choices especially if isolation between the 48V and 170V sides is needed.
