Rigidity for split flange
Dear All,
As we know, we shall design the split flange for the moment which is double of the maximum of seating or operating moment. Shall we use the same moment i.e. double of maximum for rigidity calculations??? Or we can simply use max. of operating or seating.
RE: Rigidity for split flange
Mike
which software u r using???
can u check split flange calculations in PVElite pls.
Mike
codecalc using 200 % moments for rigidity but PVElite not even bothered about rigidity.
Go to the "Flange Dialogue" screen, by clicking "Perform Flange Calculation", set flange type to "Lap Joint", then the data boxes for # of splits and thickness based on rigidity will appear. The calculation does use 200% Mo.
Mike
I have AES type exchanger. Can u check flange calculations for floating head in PVElite. Does it takes 200% moment for floating head flange???
Atish
Per TEMA 5.14 some backing rings are not subject to 200% factor, while some are. I am not able to tell what PVE is doing here, whether these TEMA rules are implemented or not.
These floating head backing rings are more generally designed per TEMA, rather than Sec VIII, Div 1.
Mike
