Automatic parameter adjustment to match some criteria
I am using NX9.
I want a body to have a certain prescribed volume by automatically adjusting some parameter.
Is this possible?
I suspect it might have something to do with the 'Requirements' function in parameters? But I am not sure how to implement it.
Here's looking at you, looking at me, looking at you
RE: Automatic parameter adjustment to match some criteria
Not really. Requirements are used to provide feedback when certain criteria has been met or exceeded but it can't be used to force the system to update in some manner, like to maintain a constant volume. What you need is to use a tool that can perform iterative tasks like the goal seek feature in the Modeling Spreadsheet or the Optimization Wizard (which is an extra cost module). To see if you have this license simply enter the term 'Optimization' in the command finder and see if you can open the dialog. If you don't have the Optimization Wizard licence you could still do a spreadsheet goal seek since that only requires that you have a Modeling license.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you.
I believe the spreadsheet goal seek method will work the easiest.
Is the spreadsheet function you are talking about the one you access through 'Expressions'? Because I think a normal excel spreadsheet can only update an excel function through goal seek, or will it be able to go back and forth between NX and excel to reevaluate the volume after every iteration?
Thank you very much cowski
Attached is another example closer to what you're looking for. It demonstrates how to use the built-in Modeling spreadsheet to compute the size of a 'Beer Glass' based on how much beer you wish it to hold.
Open the file and then go to Tools -> Spreadsheet. When the spreadsheet opens resize the Excel window so that you can see the two views of the beer glass. Now you'll see a series of cells with parameters which you can set to different values to control the 'features' of the glass, as seen in the upper view of the model on the NX display. Ultimately the spreadsheet will determine how tall a glass needs to be to hold whatever amount to enter in the 'Desired Capacity' cell. OK, once you've set your desired values, go to the Excel ribbon and select the 'Add-Ins' tab and then select 'Goal Seek' and then hit OK and you can watch the model update and iterate until the Desired Capacity is achieved.
Anyway, the part file is attached below and it will work with NX 7.5 and newer versions.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you Mr Baker, that is a very cool demonstration of the functionality.
I managed to solve my problem using that approach as well.
