Plastic strain allowable
I'm looking into developing a methodology which permits the use of a small plastic strain allowable (2%) calculated using pseudo-static linear elastic methods. The structure is effectively a simply supported beam subject to rapid high 'g' impulse loading, and the allowable would be plastic strain under bending. Common criteria such as the use of yield stress are too limiting for bending. I'm looking possibly into using strain energy density methods to determine equivalent plastic strain or something similar. Has anyone ever tried such an approach?
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
