Where can I obtain a good process plant cost data for estimating?
RE: Where can I obtain a good process plant cost data for estimating?
For which part of the world?
What kind of process plant are we speaking about? What type of equiment, for what pressure rating, level of automation, etc. ?
What are the products to be obtained from this process plant?
Define the level of accuracy you require.
There are so many questions you need to clarify before you could get a decent answer. You really do need to come back with more details.
vlad
I did not mention specifics that means all of the process plant (petroleum refinery)-cost database
Nowhere. You can get adequately accurate information like this from no one source. Sorry to be the bearer of bad news, but the closest you're going to get these days is an expensive Aspen add-on like Icarus, and that's not going to get you too close either.
www.matche.com seems to be dead, which is no big loss because their estimates were crap in our experience anyway.
Without knowing area-specific information and cost data, every attempt you make is going to be a wild guess. If this is for project economics assessment purposes, I'd look for hiring an EPCC company with experience in turnkey refinery projects to do the estimation.
I tried to see what is available on the internet and there is one document dating from 2006 and related to cost estimation of a 120,000 BPD condensate refinery located in Iran: http://www.irangi.org/res/CapitalCost/CapitalCost....
However, as others have pointed out, one should be very cautious when interpreting any cost estimation results, unless they are based on actual (executed) projects.
Dejan IVANOVIC
Process Engineer, MSChE
area specific the United States in California
You could also use QUE$TOR, however that would give you a very rough estimation.
Cost estimation requires experience and a very good understanding of what you base the estimation on.
Cheers,
Vlad
One of the reasons for employing consultants is to prepare cost estimates.
