Piles: To batter or not to batter?
Recent studies suggest that battered piles do not perform well in liquefiable soils during a seismic event, and that piers and wharves supported by battered piles have historically not done so well in past earthquakes because they attract significant loads and typically fail the deck, pile or both.
Thus the modern practice in moderate to high seismic zones is to design piers and wharves supported on plumb piles as the lateral SFRS.
What happens if you have a large piece of material handling equipment (over water) that requires a fairly rigid in-water foundation? You still have to design the foundation for seismic, and maybe even take a lower R-factor, but it seems like an all battered pile configuration is most efficient for these structures. It would sure reduce the total number of piles and minimize lateral deflections of the equipment under operating loads.
But this goes against the trend that seems to be "no battered piles".
What do you all think?
RE: Piles: To batter or not to batter?
http://www.piledrivers.org/files/uploads/45463155-...
www.SlideRuleEra.net
www.VacuumTubeEra.net
