Purpose of tabs on PCB connector jacks?
I've been designing some enclosures over the past few years and have thus far avoided jacks that have the metal spring-tabs on the sides of connectors, preferring plastic ones for a flush finished look.
I'm now presented with a part that has these metal spring tabs and I'm told this is the part we're using. I'm wondering if anyone knows the specific purposes of these tabs? I feel like they inevitably leave something to be desired from an aesthetics perspective, and so they probably have a purpose from a signal integrity perspective.
Here is a link to a part with the tabs:
http://www.digikey.com/product-detail/en/749921112...
Any experience is appreciated. Thanks,
RE: Purpose of tabs on PCB connector jacks?
TTFN
[IMG http://tinyurl.com/7ofakss]
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Because of the actual 'mating' of those fingers to your enclosure there will likely be a 'specified' opening that you need to pay attention to. Check the data sheet for that connector for the allowed clearance limits so you don't make the opening too large or small. There may also be some more rigid positioning requirements for the board placement due to all this over your prior designs.
If your EEs are requiring that kind of shielded connector it would alert me to need for 'serious' shielding being required. You should ask them about the frequencies expected and if you're designing in plastic start researching the various ways used to metalize a plastic enclosure for shielding.
Keith Cress
Keith - RE: "...the entire box's shielding concept is void and null if there are any little air gap slots present in the enclosure"
Does this mean these features are unusable if the enclosure is air-cooled?
Unfortunately the specification documents do not suggest an opening size for the enclosure. It suggests to me that the fingers may compress all the way to the walls of the jack. I'll see if we can order one and find out.
Keith Cress
The alternative of using screens to shield the air openings is often unworkable due to the Dust and Sand tests.
It really depends on the requirements.
Search for EMI grilles. Tech-Etch, Laird Tech, and some others make them. Some of them filter out dust as well, although you will need a more powerful fan.
JHG
Likely you would prepare to use one of those methods but until you do testing you don't actually do/spend money on any of them as they might not be needed. On the other hand, you don't want to be caught flat-footed with a box that will need to be redesigned or radically modified at the last moment to cover EMI issues.
Keith Cress
