Shrinkage Fitting
Shrinkage Fitting
Shrinkage Fitting
I want to know the temperature for shrinkage fitting. i want to fit a ring of outer dia 715mm, inside dia 675mm into hole of dia 684, then upto how much temperature i have to cool ring to fit into the hole ?
RE: Shrinkage Fitting
Do you know the material of which the ring, and the hole, are made?
WE DON'T.
Mike Halloran
Pembroke Pines, FL, USA
Material is Cast iron grade-250
Cast iron has a coefficient of thermal expansion of around 10.5x10-6 m/m/K
To fit a 715 diameter ring into a 684 diameter hole, you need a shrinkage strain of about 4.3%.
This would need a temperature drop of around 4000 K (or a temperature rise in the hole of around the same amount, assuming it is also cast iron).
Are you sure your parameters are correct?
Student question?
http://julianh72.blogspot.com
Thanks a lot to everyone
