What valve brand do you recommend ?????
So I ordered my "Brand Hydraulics" flow valve.
I now need to order three more hydraulic valves ( plus a couple of check valve and such ). They need to be spool type solenoid valves ( two port, two position ... blocked and flow ), 24 VDC ... two N.O and one N.C. I am going to flow about 15 GPM max.
I went to the "Hydraulic Force" web site .... just because I had used them a few years back ... and looked up a cartridge valve with a manifold ( I thought I bought them as one last time but it looks like I must buy the two parts separately ).
I was very surprised to read the "internal leak rate: 25 cu in / min @ 3500 psi"
Is this normal????
First, what is meant by "internal leak rate"? I am assuming this is the amount of oil that will leak from the "high" side to the "low" side.
To me this means that if I have a cylinder with an area of 7 sq inches, it will drop just over 3" in 1 minute????
I know I won't have 3500 psi on it when it is up holding a load ( I am thinking it will be more like 1500 psi ), I still want a minimum leak so the load will drop the minimum possible over time.
Is there a better brand ( that is still "reasonable" priced ) I should look at or a different type of valve?
I have attached the hydraulic circuit.
Thanks .... Mike
RE: What valve brand do you recommend ?????
Most of them won't be as bad as the spec, but you can't rely on a spool type directional valve to lock a cylinder. To do that, you need a lock valve, like:
http://www.metromachine.com/Hydraulics/Lock%20Valv...
This is not an endorsement of that supplier; just a clear example.
Mike Halloran
Pembroke Pines, FL, USA
Awesome!
Looking at the lock valve, they are designed for a double acting cylinder.
Since I have a single acting cylinder (using gravity to lower my lift), how can I hook this up in my circuit?
They mention a single lock but don't show an example of it or how it would hook up.
Thanks ..... Mike
Search for pilot operated check valve.
Compact Controls, Hydraforce, Sun Hydraulics, for example
Ted
I understand how the pilot check will work on a double acting cylinder. The "pressure" side will release the check on the side now connected to the tank. With no pressure on both sides, both sides are held by a check valve.
On my single acting cylinder, I am a bit confused.
I "load check" will hold fluid from going back through the circuit on the "power" side.
Because there is gravity down, there is nothing to release a piloted check on the lowering circuit.
In fact, I was going to go with a "poppet" type solenoid valve. They have an incredibly low leak rate ... 3 drops per min.
The only place this will not work is on the valve shown to the left of the circuit. It would work when the system is not energized ... so it would hold the load. I am worried that when lifting there will be higher pressure on the bottom of the valve and then it could bypass the flow control valve and flow directly to the cylinder.
Might be a dumb question but can I put two of these solenoid valves back to back with the check portion pointing in opposite directions?????
I'm sure others make very similar models but here is the ones I was looking at: http://hydraforce.com/Solenoid/Svpp2w.htm
Thanks again ..... Mike
Kiwitom235 ....
Sorry didn't see your post, you must have been typing the same time I was.
This is exactly what I was looking for!
The valve I was worried about only has to flow in one direction ( during the lowering cycle ) but needs to block in both.
Fantastic!
Thanks so very much .... my wife says if I just had you guys move in for a week or two I could get caught up on all my projects!
Thanks again .... Mike
Just FYI .... Motion Industries quoted me almost $400 for the flow valve with 3-4 weeks delivery. The factory sent me to Brand Power Fluid ( their sister company ) .... $300 and in stock.
HAH, funny that, great minds think alike ;)
