Thermal simulation of a simple storage tank using TRNSYS 16
Greetings! The task at hand involves a metal tank of simple geometry (rectangular, open at the top), exposed to the environment. The tank is filled with fluid of known thermophysical properties. I want to simulate the problem using TRNSYS 16 and, therefore, predict the fluid's temperature. Is there any a specific type that thermally simulates the tank? How would you approach it?
Thank you in advance.
