Extract Advance Weight Management Data API
I need to extract all the Weight Management which is exported to excel when done manually for a top level assembly including its children.
Manually the menu is available in "Analysis" Menu.
I found an API
public void EstabPartProps
Tag part,
double accuracy,
bool recurse,
UFWeight..::.UnitsType units,
out UFWeight..::.Properties properties,
out UFWeight..::.Exceptions exceptions
which is a wrapper method for UF_WEIGHT_estab_part_props
int UF_WEIGHT_estab_part_props
const tag_t part,
const double accuracy,
const logical recurse,
const UF_WEIGHT_units_type_t units,
UF_WEIGHT_properties_t * properties,
UF_WEIGHT_exceptions_t * exceptions
const tag_t part(Input) :The part whose weight properties are to be
established.
const double accuracy (Input): The accuracy to which the part's properties
are to be calculated.
const logical recurse (Input) : True if the properties are to include
components of the part, false otherwise.
const UF_WEIGHT_units_type_t units (Input): The units in which the properties are to be returned.
UF_WEIGHT_properties_t * properties (Output) : The established properties of the part.
UF_WEIGHT_exceptions_t * exceptions (Output) : to be freed Any exceptions encountered during the calculation. This must be freed by
calling UF_WEIGHT_free_exceptions.
If i use this i can get the Weight management details only for the top level assembly. When i pass the "TRUE" flag to this API which states that "it has to be set as TRUE if properties are to include components of the part, false otherwise".
Still i am not getting all the components data.
And also i am confused between the terminology used in the documentation. There are three differenct API's for Part, Component and Solid.
UF_WEIGHT_estab_comp_props
UF_WEIGHT_estab_solid_props
How is it different.?
Santosh
I found an API
Tag part,
double accuracy,
bool recurse,
const tag_t part,
established.
Santosh
