Selection problem with NX re-use library object
Hello All,
I recently started to use NX re-use library custom parts. I got one example file from this forum (full package including .part, .xls, .bmp, ,krx files) and did some editing on those to create new custom library parts.
Now, everything works fine except the fact that I am unable to select the features of this parts (except datum), once it is added to an assembly. Component can be selected by part navigator but simple mouse click on part geometry in screen does not work. the file which I created is attached, please have a look n the same and advise me where I made mistake.
Thanks In Advance,
Nithin
NX8.0
Thanks In Advance,
Nithin
NX8.0
