Rename topology
Rename topology
Rename topology
Is it possible to rename the topology of a part? For instance, I would like to loop through all the faces of a part and rename each one with the following template: from "Face" to "FaceX" where X is a number from 1 to N.
Thanks you,
Antoine
RE: Rename topology
if you want to rename it in a spec tree the answer is yes. macro can be used to speed up renaming.
