IS THIS MANIFOLD POSSIBLE
ok so I have seen some pretty funky muffler pipes. However this isnt a muffler, it is holding liquid glycol/ water mix. The model in the pic shows three 90 butt weld pipe ends kind of put together with a 1.0 pipe, another 90 into a triclamp fitting. its stainless steel, and 1.0" od and .109" wall, or 1.315 OD and 1.09" ID. Is this possible and how? I want this nice smooth swoop type flow into the main line, I do not want to use Tee fittings as it will kill flow with the 90's
RE: IS THIS MANIFOLD POSSIBLE
Try lateral tees or latrolets.
Piping Design Central
the thing about these Y and laterolets id they come out on an angle. I want the inlets to come out perpendicular to the straight pipe like you see in my model
You may have just found an application for 3-D printing.
You could cobble it together by cutting down ells, but it wouldn't be smooth inside.
Yah the smoothness wouldnt be as good, and I dont think 3d printing is at that stage yet.
LittleInch those are nice fittings
I wonder how strong those swept tees are, looks like two pieces welded than polished.
Take a pile of these:
http://www.mcmaster.com/#standard-butt-weld-tube-e...
to any local marine exhaust shop
(include a few spares)
and ask them to weld up your manifold.
The mcmaster parts should be able to handle your 10 psi design pressure.
Hint: If you're expecting hoses to stay on the elbows, ask the shop to weld or form 'hose beads' a short distance from the ends.
Mike Halloran
Pembroke Pines, FL, USA
MikeHalloran .....
thats funny thats what I actually am using in my model, three 90 fittings.
