Nd@YAG, Gas byproduct Reduction
I currently use a Nd:YAG for welding ST/ST components. I experience a deposit of a black powder like substance on the components afer welding. This can vary depending on the direction the shield gas (ARGON-Pure)is applied in but is ever present to some degree. Has anyone had similiar experiences and if they have, how can you eradicate this problem, if at all?
RE: Nd@YAG, Gas byproduct Reduction
TTFN
Stainless AISI316L welded to same material and also AISI316L welded to AISI304
Cheers
The amount of deposition is dependant on the joint geometry. With a simple butt weld in two flat components, there should be little or no "soot" deposit.
With a corner weld, where there is a vertical surface close to the weld area, then there will be a heavy deposit of "soot" on the vertical surface.
This is true even when welding in a completely inert atmosphere such as would be encountered in a glove-box.
The upside is that this stuff vipes off easily.
Cheers
FGreen
