Copy front view from Drafting module to a sketch in Catia V5.
Would you guys show me the way to copy 2d generative drafting to a sketch in Part Design ? I've tried the way in this video but nothing happened after paste command .
RE: Copy front view from Drafting module to a sketch in Catia V5.
> Save the Drawing as a DXF
> Open the DXF File
> Copy the Geoemtry from the DXF
> Switch to a CATPart in Part Design workbench
> Create a Sketch
> With the Sketcher Workbench open, Paste the Geometry into the sketch
--Doug
isolate the view
select the view (not the content in the view, but the view) = copy
go in catpart = paste
Eric N.
Paste error : It is not allowed to paste . This dialog shows up .
Are you sure you copy the view ?
Eric N.
itsmyjob right. check if you are copying the view..any way the macro can do the job.. i don't have it at home but i'm gonna upload the macro at Sunday when i get back to work.
Yes, i did copy the view . And if you isolate the view, the content in the view would turn into black.
Is there any difference between your version and mine ?
