Does any have rates of corrosion (acid attack from peat)of concrete pipes subject to low pH 4.5-5.5
Im interested in any research on corrosion rates of concrete pipes subject to weak acid attack and how this will reduce the pipe life.
Also the affects on the weak concrete used in the poured concrete base of insitu poured manhole bases.
RE: Does any have rates of corrosion (acid attack from peat)of concrete pipes subject to low pH 4.5-5.5
http://www.cclynch.com/resources/Hydrogen-Sulfide-...
