Grooves on a gear
Grooves on a gear
I have seen some gears for the agriculture machines having one or more shallow grooves on the outer dia.
http://files.engineering.com/getfile.aspx?folder=9...
What are these grooves for?
Thank you in advance for your input.
RE: Grooves on a gear
The reason for using a series of grooves on the tooth top lands is because it provides a quick and fool-proof method to visually confirm the correct gears are being used. Back in the olden days, before the availability of laser marking systems, turning a set of grooves in the OD of the gear blank was a cheap way to permanently ID the part.
Here's a related link.
