Link note triangle
Link note triangle
Link note triangle
I came across a drawing created by someone not here anymore.
The note triangle in a view is linked to a note triangle in a drawing note triangle.
Changing the triangle number in the view will change the number in the drawing note within the triangle.
How do I create this, and how do I edit it?
I have looked over every link to property option, no go.
Thanks.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
RE: Link note triangle
Man, I've done this before but can't remember how I did it...where's Lorono when you need him?
Jeff Mirisola, CSWE
My Blog
Ah! Finally got it.
Select text within note, select "Link to Property".
In Link to Property window, select "Component to which the annotation is attached", OK.
Then select the triangle (or note/dim/etc) in the view.
They are linked. The edit works one way. Change the item in the view will change in the note, not the other way.
I will turn in a suggestion to SW for this.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
