Solution Dependent Variable(SDV) ex.(SDV1,SDV55...) stand for?
Hallo,
I am Nithin and working on my Thesis right now and i would like to know where can i find the details for Solution Dependent Variables(SDV) ex. SDV1, SDV55,SDV79.. stand for?.
Any help would be much appreciated.
Kindr regards,
Nithin
Kindr regards,
Nithin
RE: Solution Dependent Variable(SDV) ex.(SDV1,SDV55...) stand for?
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
If you are writing a user subroutine, you can define user-dependent state variables. These are recalculated/tracked throughout your analysis and will typically vary from one subroutine to another. If you are using a specific subroutine and want to figure out what SDV1, SDV2, ... are you should open your fortran .f file, read your code, and see for yourself.
Good luck,
Dave
Many thanks for your suggestion, i will look into my UMAT subroutine and will see if there is any luck.
Nithin
And @Ice Breaker, yup i am using UMAT subroutine to my model.
