PSV Discharge Coefficient for Dense Phase Fluids
I'm sizing a PSV for a dense phase fluid. It will enter the PSV as dense phase but will become two phase leaving the PSV.
What discharge coefficient should I use for preliminary PSV sizing. Based on API 520 Part 1 guidance I'm unsure whether to use 0.975 (gas) or 0.85 (two phase).
Thanks.
Thanks.
RE: PSV Discharge Coefficient for Dense Phase Fluids
you may try to estimate the vena contracta conditions and then decide which parameter to apply, for the procedure see
"http://eng-tips.com/viewthread.cfm?qid=329093"
See also the attachment and http://people.clarkson.edu/~wwilcox/Design/reliefv... and http://frame.leser.com/engineering/file/EHB_en_7.4... for further info.
Dejan IVANOVIC
Process Engineer, MSChE
Dejan IVANOVIC
