Horizontally curve inverted L PTB
Hi Good day everyone
Does anyone have design experience with the horizontally curve inverted L-shaped Post Tension Beam?
I am going to
(1) provide transverse U-links for tendon confinement.
(2) Design the protruding beam depth as a cantilever (slab as pin support) with the lateral load from tendon. Please refer to attached plan & section.
If you guys have any example calculation or anything I can refer to, please share with me and I will be grateful.
RE: Horizontally curve inverted L PTB
I've done a few.
1) not sure the hairpins are necessary as the tendons can push against the stirrups and slab.
2) instead of a cantilever, analyze it as beam torsion that gets resolved through a fixed connection with the slab.
