Solid edge file properties
We use file properties to populate our drawing title blocks in ST7.
Currently, when they need updating/changed, we must either go back to file in question or use the property manager.
For large assemblies, this can be time consuming. Wondering if anyone knows of any way to update/change properties of a part used in a .dft file from the .dft file without using the property manager or going back to the part in question?
I doubt there is but it would sure be nice.
RE: Solid edge file properties
Revision manager may be a way to do it, but still opening another 'application'.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Playing with this some more, I can change properties via windows explorer or the insight server interface, though that wont change anything I have open until I close and reopen again. I cant figure out how to "Reload" what I already have open to update the properties of the loaded file in my cache.
thanks all. Doesn't seem to be any better options.
Start Solid Edge then click the application icon in the top left corner.
You can start Prop Man from there and select individual files or a whole folder.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
