ChamferBuilder
ChamferBuilder
Anyone have experience using ChamferBuilder. I wrote a function for the creation of a chamfer; however, in some instances the chamfer is coming in the wrong direction and needs to be flipped. This is typically done manually in NX when installing a chamfer, the designer looks at the resulting chamfer and then reverses the direction. However, in my situation with code, I don't want to have to write code in interrogate the chamfer and then reverse direction. These chamfers are being applied to hole feature, so the depth is always along the length of the hole.
Any ideas?
Here's my function:
Any ideas?
Here's my function:
CODE --> vb.net
Private Function CreateChamfer(ByVal iDepth As Double, ByVal iAngle As Double, ByVal iEdge As Edge) As Features.Feature
Dim chamferBuilder1 As Features.ChamferBuilder
chamferBuilder1 = workPart.Features.CreateChamferBuilder(Nothing)
chamferBuilder1.Option = Features.ChamferBuilder.ChamferOption.OffsetAndAngle
chamferBuilder1.Method = Features.ChamferBuilder.OffsetMethod.EdgesAlongFaces
chamferBuilder1.FirstOffset = iDepth.ToString()
chamferBuilder1.Angle = iAngle.ToString()
chamferBuilder1.Tolerance = 0.001
Dim scCollector1 As ScCollector
scCollector1 = workPart.ScCollectors.CreateCollector()
Dim nullEdge As Edge = Nothing
Dim edgeTangentRule1 As EdgeTangentRule
edgeTangentRule1 = workPart.ScRuleFactory.CreateRuleEdgeTangent(iEdge, nullEdge, False, 0.5, False, False)
Dim rules1(0) As SelectionIntentRule
rules1(0) = edgeTangentRule1
scCollector1.ReplaceRules(rules1, False)
chamferBuilder1.SmartCollector = scCollector1
Dim feature1 As Features.Feature
feature1 = chamferBuilder1.CommitFeature()
chamferBuilder1.Destroy()
Return feature1
End Function
RE: ChamferBuilder
Mark Rief
NX CAM Customer Success
Siemens PLM Software
RE: ChamferBuilder
Below is a proof of concept journal.
Caveats:
- it expects that the selected edge is attached to a cylindrical face (it assumes this cylindrical face is the hole)
- if the chamfer feature creates more than 2 edges, the journal will almost certainly fall over
I believe that both of these limitations can be overcome with additional code checks. The code seems to work well in simple test cases (the edge chosen is a single entity and it connects a planar face to a cylindrical face).CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Imports NXOpen.UF Module Module1 Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow Sub Main() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If lw.Open() Const undoMarkName As String = "chamfer along depth" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim myEdge As Edge = Nothing If SelectEdge("Select an edge", myEdge) = Selection.Response.Cancel Then Return End If CreateChamfer(0.06, 15, myEdge) lw.Close() End Sub Function SelectEdge(ByVal prompt As String, ByRef selEdge As Edge) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select an edge" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(0) As Selection.MaskTriple Dim selObj As TaggedObject = Nothing With selectionMask_array(0) .Type = UFConstants.UF_solid_type .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_EDGE End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selObj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then selEdge = selObj Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Private Function CreateChamfer(ByVal iDepth As Double, ByVal iAngle As Double, ByVal iEdge As Edge) As Features.Feature Dim holeDirection As Direction = Nothing Dim dirError As Boolean = True Try holeDirection = FindHoleDirection(iEdge) dirError = False Catch ex As Exception lw.WriteLine("FindHoleDirection error: " & ex.Message) End Try Dim chamferBuilder1 As Features.ChamferBuilder chamferBuilder1 = workPart.Features.CreateChamferBuilder(Nothing) With chamferBuilder1 .Option = Features.ChamferBuilder.ChamferOption.OffsetAndAngle .Method = Features.ChamferBuilder.OffsetMethod.EdgesAlongFaces .ReverseOffsets = False .FirstOffset = iDepth.ToString() .Angle = iAngle.ToString() .Tolerance = 0.001 End With Dim scCollector1 As ScCollector scCollector1 = workPart.ScCollectors.CreateCollector() Dim nullEdge As Edge = Nothing Dim edgeTangentRule1 As EdgeTangentRule edgeTangentRule1 = workPart.ScRuleFactory.CreateRuleEdgeTangent(iEdge, nullEdge, False, 0.5, False, False) Dim rules1(0) As SelectionIntentRule rules1(0) = edgeTangentRule1 scCollector1.ReplaceRules(rules1, False) chamferBuilder1.SmartCollector = scCollector1 Dim feature1 As Features.Feature feature1 = chamferBuilder1.CommitFeature() chamferBuilder1.Destroy() If Not dirError Then CheckChamfer(iDepth, iAngle, holeDirection, feature1) End If Return feature1 End Function Private Sub FlipChamfer(ByVal theChamfer As Features.Chamfer) Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Edit Feature Parameters") Dim chamferBuilder1 As Features.ChamferBuilder chamferBuilder1 = workPart.Features.CreateChamferBuilder(theChamfer) chamferBuilder1.ReverseOffsets = Not chamferBuilder1.ReverseOffsets Dim feature1 As Features.Feature feature1 = chamferBuilder1.CommitFeature() chamferBuilder1.Destroy() Dim nErrs1 As Integer nErrs1 = theSession.UpdateManager.DoUpdate(markId1) theSession.Preferences.Modeling.UpdatePending = False End Sub Private Sub CheckChamfer(ByVal iDepth As Double, ByVal iAngle As Double, ByVal theDirection As Direction, ByVal theChamfer As Features.Chamfer) Dim theAngularTolerance As Double theUfSession.Modl.AskAngleTolerance(theAngularTolerance) If Math.Abs(45 - iAngle) < theAngularTolerance Then 'chamfer is close to 45°, no need to flip chamfer Return End If Dim depth1 As Double = MeasureChamferDepth(theChamfer, theDirection) Dim diff1 As Double = Math.Abs(iDepth - depth1) FlipChamfer(theChamfer) Dim depth2 As Double = MeasureChamferDepth(theChamfer, theDirection) Dim diff2 As Double = Math.Abs(iDepth - depth2) If diff1 < diff2 Then FlipChamfer(theChamfer) End If End Sub Private Function FindHoleDirection(ByVal theEdge As Edge) As Direction 'finds the axis of a cylindrical hole Dim holeFaceTags() As Tag = Nothing theUfSession.Modl.AskEdgeFaces(theEdge.Tag, holeFaceTags) 'get faces connected to selected edge Dim holeFaces As New List(Of Face) For Each temp As Tag In holeFaceTags holeFaces.Add(Utilities.NXObjectManager.Get(temp)) Next Dim holeFace As Face Dim holeFaceRadius As Double Dim found As Boolean = False Dim dirArray(2) As Double For Each temp As Face In holeFaces If temp.SolidFaceType = Face.FaceType.Cylindrical Then Dim faceType As Integer Dim pt(2) As Double Dim dir(2) As Double Dim box(5) As Double Dim rad As Double Dim radData As Double Dim normDir As Integer theUfSession.Modl.AskFaceData(temp.Tag, faceType, pt, dir, box, rad, radData, normDir) If found Then 'not the first cylindrical face found, check to see if it is smaller than the first If rad < holeFaceRadius Then holeFace = temp holeFaceRadius = rad dirArray(0) = dir(0) dirArray(1) = dir(1) dirArray(2) = dir(2) End If Else 'first cylindrical face found, use it as hole face holeFace = temp dirArray(0) = dir(0) dirArray(1) = dir(1) dirArray(2) = dir(2) holeFaceRadius = rad found = True End If End If Next If Not found Then Throw (New Exception("no cylindrical face found")) Return Nothing End If Dim holeDir As Direction Dim origin1 As Point3d = New Point3d(0.0, 0.0, 0.0) Dim vector1 As Vector3d = New Vector3d(dirArray(0), dirArray(1), dirArray(2)) holeDir = workPart.Directions.CreateDirection(origin1, vector1, SmartObject.UpdateOption.AfterModeling) Return holeDir End Function Private Function MeasureChamferDepth(ByVal theChamfer As Features.Chamfer, ByVal chamferDirection As Direction) As Double Dim depth As Double 'if the chamfer feature creates more than 2 edges, this code will need to be improved Dim chamferEdges() As Edge = theChamfer.GetEdges Dim nullNXObject As NXObject = Nothing Dim measureDistanceBuilder1 As MeasureDistanceBuilder measureDistanceBuilder1 = workPart.MeasureManager.CreateMeasureDistanceBuilder(nullNXObject) With measureDistanceBuilder1 .InfoWindow = False .AnnotationMode = MeasureBuilder.AnnotationType.None .Mtype = MeasureDistanceBuilder.MeasureType.Minimum .ProjectionVector = chamferDirection .Object1.Value = chamferEdges(0) .Object2.Value = chamferEdges(1) End With Dim unit1 As Unit If workPart.PartUnits = BasePart.Units.Inches Then unit1 = workPart.UnitCollection.FindObject("Inch") Else unit1 = workPart.UnitCollection.FindObject("MilliMeter") End If Dim measureDistance1 As MeasureDistance measureDistance1 = workPart.MeasureManager.NewDistance(unit1, chamferEdges(0), chamferEdges(1), chamferDirection, MeasureManager.ProjectionType.Minimum) depth = measureDistance1.Value measureDistance1.Dispose() measureDistanceBuilder1.Destroy() Return depth End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
