Quickgroup
Quickgroup
Quickgroup
Hi All,
Does anyone know if there is a way to toggle groups on and of like in ACAD? In ACAD it's CTRL+H.
Thank you,
Simon.bigsmile
RE: Quickgroup
I haven't used ACAD since 2000 but, try this. It may do what you want.
Type SETENSELMODE in command line.
0 ungroups and 1 regroups.
It doesn't hide anything, so if that is what you're looking for, this command isn't it.
Sylvia
RE: Quickgroup
Hi Sylvia,
That's exactly what I was after!! Thank you! thanks
SETENTSELMODE
0 Does not select Groups or associative Hatches
1 Selects Groups
2 Selects associative Hatches
3 Selects Groups and associative Hatches
RE: Quickgroup
See thread 1480-375989. It describes how to create a button that will enter the command, instead of typing it all the time, or perhaps you have a programmable keyboard or mouse.
RE: Quickgroup
Seen that post you did, had it bookmarked!
I have two extra buttons now to set the SETENTSELMODE to one or zero.
I did have a go at changing these macros that toggle settings but couldn't crack it! Don't know enough about Diesel.
^P'orthomode $M=$(if,$(and,$(getvar,EnblOrtho),1),$(-,$(getvar,EnblOrtho),1),$(+,$(getvar,EnblOrtho),1))
^P$M=$(if,$(and,$(getvar,SetESnpMode),16384),'osmode $(-,$(getvar,SetESnpMode),16384) )$(if,$(eq,$(getvar,osnapoverride),0),'osnapoverride 1)
Tried to do something like this,
^P'SETENTSELMODE $M=$(if,$(and,$(getvar,SETENTSELMODE),1),$(-,$(getvar,SETENTSELMODE),1),$(+,$(getvar,SETENTSELMODE),1))
but I can't get it to work.sad
RE: Quickgroup
HA!
Just did it!!!!!!!!!!!!!!!!dazed
That last one works!!!!!!!!
Must have not done something before, SORTED!!!
RE: Quickgroup
I'm SO happy right now!
I've made a new shortcut key, CTRL=H, and the groups toggle on and off like in AutoCAD now!!!! YAY!
