Phase Transformation during quenching process
Hi everybody,
I simulating quenching process with using heat transfer module in workbench and I need to take into account martensite phases transformation. In summary I need add external energy Q to every gaussian integration point which is depend form cooling rate (the temperature during phases transformation decreasing slower. Do you know how can I do this with using ANSYS. I trying to use phases change in heat transfer models described widely in attachment file but this is not what I need because it is not depend from cooling rate and fit more to solidification than phases transformation.
Thanks for any help
Thanks for any help
