Catia V5 not showing points
We just upgraded to Catia V5 R21 and in part design it's showing planes about 4 times the size they should be as well as not displaying any points created with GSD
Any thoughts or solutions?
RE: Catia V5 not showing points
@zagarao
I think the size of planes is controlled in Tools > Options. I don't have CATIA open at the moment, but it's probably on the Display tab under the Infrastructure > Part Infrastructure section.
If not, then try the Mechanical Design section of the tree in the Tools > Options window. Lastly, you might try one of the tabs under General > Display.
Drew Mumaw
http://www.textsketcher.com/
http://www.drewmumaw.com/
It could be your view setting.
View - Render style - Custom View - All points.
Win 7
23SP5/24SP3, 3DVIA Composer 2015
tools options:
With Pixel Culling >= 3 you wont see point in 3D.
Lower the value to see points.
Eric N.
Worked like a charm, thanks guys!
Damn itsmyjob, that is some funky stuff. You can't tell me that was the intention when Dassault thought of Pixel Culling as a technique to simplify the visualisation process?
it does help when you have big assembly with zillions of tiny bits...
Eric N.
