Stopping Excel from changing data through OLE
Hi All
I have a Visual basic program i've developed to control the stock levels at work.
To print out reports in a logical set out i've sent the data from a MSFlexGrid(which i use to display on screen) to Excel so as it will print in columns.
This works fine but excel in all its genius changes some ID numbers like "4-8093" to a date like "Apr-93".
Can Anyone help???
RE: Stopping Excel from changing data through OLE
You might try converting those numbers to strings before sending them to Excel.
Thanks for the try but Excel still sees the data in date format.
I've noticed that the Excel OLE object has a "rejectallchanges" method. Pehaps this my be helpful if i knew its parameters. Its askes for [when,who,where].
Isn't problem solving fun.
tar
just ad ' as first character of the string
lu
Of course.  The simplest solution is always the best.
Thanks mate, I'll give it a go.
