filler rod ,cupola repair
ASTME A-592 a step below corten plate steel. Is the filler to be 70xx series weld rod or I suppose 80xx series filler? stick weld is the method available.
RE: filler rod ,cupola repair
I don't know the answer to your question, but try posting it on the Welding, Bonding & Fastener engineering Forum. Somebody there probably will.
   Bruv
