Code of SAP2000
Code of SAP2000
Code of SAP2000
I wanted to know if it is possible to get a text or command code of all the commands that we have executed on SAP2000.
For example,
If I want to use a part of the modelling to be same for 5 different models, if I can access the code file, I can easily copy paste just that part of the code instead of repeating it all?
This can be done in staadPRO. Is this possible in SAP2000 too?
Thank you.
RE: Code of SAP2000
Use .s2k files to import/combine models. Any SAP2000 model can be exported into .s2k and then imported into other SAP2000 models.
RE: Code of SAP2000
You mean the .$2k file? And also, is there not any file which I can open on Notepad or something? And make changes to it?
Thank you for your quick reply.
RE: Code of SAP2000
No, actually I meant what I wrote, .s2k, not .$2k. You don't see import or export of .$2k files in the File menu, do you? .$2k may possibly subsitute for .s2k, but my original advice still stands.
RE: Code of SAP2000
Yes! I got it! Thank you so much for your reply!
RE: Code of SAP2000
Also, Staad sucks.. when the company I worked for 6 years ago was transitioning from Staad to SAP, combining of separate models was at that time a HUGE advantage for SAP compared to Staad. No comparison really.. I'm guessing from your comments that Staad has improved somewhat in combining separate models.
RE: Code of SAP2000
Oh! Once I figured this out. Yes Staad might be a little harder. Thank you.
RE: Code of SAP2000
In staadPRO, you know how there is a text file in which you can change the commands? One small change in command can change the whole program? Is there something like this in SAP?
I managed to export the file to word. But it is huge and very tedious I think.
Thank you.
