tension lap joint
tension lap joint
tension lap joint
Hi All,
Has anyone used the elastic bearing stress concentration factor (Kbe) to calculate the maximum stress along the bearing plane of a single bolt tension joint. I am applying this to FRP material and I can only get these to converge on my FEA in the higher w/d and e/d range (>5). Any thoughts?
