NACE Sour Service Gasket
Are there any special gasket requirements for sour service NACE MR0175 lines? Is a standard 316 RF spiral wound gasket accepable?
Thank you!
RE: NACE Sour Service Gasket
engpes I don't have a copy handy, but as I recall gaskets are not within the scope. Having said that, I believe stainless spriral wound would be acceptable. You should probably seek further confirmation however.
Mike
You might want to check Klinger Gasket Expert software just for reference see what it comes up with depending on your fluid:
http://www.klinger.co.uk/services/gasket-selection
I hope this is not considered as advertising.
