Difference between 11 kV submarine cable and normal cable
Is there any major difference between a 11 kV submarine cable and the normal cable?
I want to know specifically the cable capacitance (charging current) value. Is it almost same for both or different?
RE: Difference between 11 kV submarine cable and normal cable
The cable was damaged 4-10 times in a year by ship anchors.
Parallel a marine cable was running -pvc insulated also but steel wire armored and hard rubber sheathed. No damage was recorded for many years. Conclusion:
In my opinion, if the cable is built for marine conditions will withstand easily the marine environments.
