Etabs Modelling
Etabs Modelling
Hello everyone,
I need some clarifications in Etabs modelling. How do i apply lateral loads (EQ) in etabs manually? What's the difference between lump lateral mass at storey level and include lateral mass only of mass source in DEFINE? Which option i should check when i enter the EQ loads manually. I m pretty much done with modelling except the application of lateral loads. I indeed applied the lateral loads as user options in static load case (applied @ COM). When i analysed the structure shows the vertical loads and also the user defined horizontal lateral loads @COM. The EQ lateral load application is kind of tricky in etabs. Kindly, help me out in solving this issue.
Vignesh.S
(Structural Engineer)
Vignesh.S
RE: Etabs Modelling
Your manual application of EQ load, is OK.
For clarifications regarding defining & proper application of mass source in ETABS, you may refer to following links:
1. Link
2. Link
A good structural engineer is often a blessing for others.
RE: Etabs Modelling
