Digital Vernier Interface with a PC
3
Hello All,
I need to record the continuous elongation of a bolt as torque is applied. I was planning on using an electronic digital vernier and connecting it to the pc similar to the below:
http://digital-caliper.co.uk/product_info.php?prod...
Does anyone have any experience of this? Or know of a cheaper equivalent product?
RE: Digital Vernier Interface with a PC
How do you plan to measure and record the torque with that caliper?
I'm just curious what a "digital vernier" is.
The link describes a digital caliper with a PC interface. Where does the vernier part come in?
MintJulep, the torque will be measure with a torque wrench, the elongation is to be measured with calipers.
Redpicker, please read my post as "digital calipers with a PC interface", disregard the vernier aspect. I often refer to vernier gauges as calipers.
Continuous elongation of an externally threaded fastener usually is measured using strain gages or an ultrasonic transducer. Before and after length measurements with a micrometer, not a caliper, is common too. An alternative is to measure the clamping force instead of elongation using a force washer. I recommend looking at the following:
http://www.strainsert.com/products/custom-internal...
http://www.mcrts.com/products/UltrasonicSensors/UT...
http://www.pcb.com/FasteningTechnology/ForceWasher...
So how do you record the torque with a torque wrench?
If you want a torque vs. elongation curve you need to measure and record both.
If you want "continuously" then the measurements need to be recorded simultaneously.
If you only need discrete points then a pad of paper and a pencil work just as well as a PC interface.
Yes good point MintJulep.
Thanks for the information CoryPad. Some interesting bits of kit there.
MicroRidge makes interfaces for Mitutoyo and other manufacturer communications standards that serve as a USB-based standalone keyboard wedge- no software required.
Very convenient, I have deployed several within our company.
-AK2DM
"It's the questions that drive us"
