DAQ channel initialization
I am writing a daq program in labVIEW. It basically is an array of push buttons that control different lines on hardware.
I have a daq task that controls 8 lines. Then I send it through a while loop so the software user can toggle the push buttons to turn on and off stuff.
However, whenever I open my program, on the front panel, the array of push buttons is grayed out. So, it will give me an error since the boolean array controls 8 lines, and if the array is grayed our it controls 0. So, I have click each push button to initialize it. Is there a way that when I open the program it will have all the contents in that boolean array initialized to false rather then initialized to nothing when I open the program?
Here is a picture of my front panel grayed out: http://files.engineering.com/getfile.aspx?folder=0...
Here is a picture of my block diagram: http://files.engineering.com/getfile.aspx?folder=3...
