Storefront / Window Anchorage - No T or F Anchor
Is my understanding correct? ->
For most large curtain wall systems there are T and F anchors which fit inside the vertical mullion. These anchor the system to the substrate and allow for vertical movement of the substrate and thermal/expansion contraction of the mullion. However for most single story storefront systems, these anchors are not used. Typically the vertical mullion is fastened to the head and sill mullion (via a shear block) and the head and sill mullions are fastened to the substrate. However, a gap is present between the storefront and the substrate (say 3/8 - 1/2 or whatever is needed). In order to achieve this gap, the anchor is checked in bending. Typically a fixed-guided end conditions are assumed. I could see anchoring into steel, concrete or wood as being fixed, but what about cold formed steel? I could see the aluminum mullion, if it were a tube section as providing as a guided condition, but what about when it is a channel, or you are fastening through the thermal break material? Find attached for further explanation.
Also I typically see extra fasteners at jambs, maybe for wind load or door weight? I don't normally see calcs for door weight or operable windows but it's possible I just haven't seen enough examples.
RE: Storefront / Window Anchorage - No T or F Anchor
We also do a fair amount of CFS and I know what you mean. I have been going over some example projects from other companies and it seems like what I am describing is what they are assuming. However most projects are for larger curtain walls with the T&F anchors and all works out a little easier. With a storefront or window, it seems that the anchor is the cantilever member. I'm not sure how this works with CFS though. I suppose you could still resolve the moment caused by the eccentricity with a tension in the anchor and compression on the edge of the mullion.
EIT
www.HowToEngineer.com
Jim.
So I'm guessing that there really is no standard way for the storefront situation...
EIT
Found this, jimstructures, that helped me 'picture' what they are exactly:
