Pressure testing requirement for steel Elbows
Hello All,
Does anyone know of any pressure testing requirement or code for pipeline elbows. I am talking of gas pipelines - Transmission and High pressure distribution pipelines.
For instance, what is required when pretested pipes are installed with elbows? Thanks
RE: Pressure testing requirement for steel Elbows
Testing of bends on a pipeline (not "elbows") is undertaken as part of the entire pipeline.
Is there any provision in any code that allows for installation of "pretested pipe" together with factory made bend/elbow (like 3R 45 deg Ell) without hydrotesting the entire system?
Please, let me know if you know of any such clause. Thanks
Pipeline Safety Regulations, Title 49, Code of Federal Regulations.
1. §192.503 General Requirements
(a) No person may operate a new segment of pipeline, or return to service a segment of pipeline that has been relocated or replaced, until-
(1) It has been tested in accordance with this subpart and §192.619 to substantiate the maximum allowable operating pressure; and
For short sections of pipe, §192.505(e) provides an exception for conducting a post installation strength test if the test is considered impractical.
