Avoid deleted/hided lines come again after regerate/update
I have a motor model on which the manufacturer name is embossed. I want that name to be not shown in my drawing. For that, I hide that name in the drawing. Everything fine and then when the model and drawing was regenerated, that name again become viewable in the drawing. I tried by delete that lines and checked if that again come when regenerated. It is again coming. For the time being, I hide that names by multiple lines. Is any setting there in OPTIONS to keep the deleted or hided lines remain in same condition after regenerate. Kindly give any idea.
Suresh
Suresh
RE: Avoid deleted/hided lines come again after regerate/update
Check tools > Options > Mechanical Design > Drafting > Geometry tab > Enable: Keep Graphical Dress-up Manually Set on Geoemetry this might also make a difference.
--Doug
If the name is embossed in a part you need to see, find the embossed name pocket in the part tree and deactivate it.
Harold G. Morgan
CATIA, QA, CNC & CMM Programmer
Thanks for the reply and the solution provided. I am using R20. Keep graphical dress up option is available in draft > view > generated geometry.
It is working fine.
Hi HGMorgan,
Thanks for the reply. My motor model is read only and I have no rights to modify. So, I unable to do as you mentioned by deactivate the embossed part. And also, as the motor is single part, I unable to use overload properties.
Suresh
