nx8.5 sketch mirror function
Hi
The mirror function in nx8.5 is improved over nx6 mirror
it has 1 constraint symbol instead of many in nx6
but I was expect that when I delete the constraint
the mirrored curves also do
Is there a way to delete the mirrored curves in 1 shot
Thanks in advanced
Thanks in advanced
RE: nx8.5 sketch mirror function
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for the response
because this constraint build the mirrored curves in its operation
and I expect that when I delete the constraint I'l be asked
if I want to delete the mirroed curves also (an option its nice no!?)
I'm thank you again
You right but sometimes you need mirroring as a short way to achive the target shape
and maybe use extrude or revolved to build your solid body
Thank you for your response
And to that point, there are other situations where additional curves are added to a sketch as part of a 'constraint' operation such as when a curve(s) is offset or a 'Pattern' of sketch curves is created. In those cases as well, deleting the constraint does NOT delete the additional curves that were part of that constraint scheme.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you very much
