Abaqus/Explicit: Dynamic failure models
There are two simple models for Dynamic failure, TENSILE FAILURE and SHEAR FAILURE - http://abaqus.ethz.ch:2080/v6.14/books/usb/default...
So far what I understood, with element deletion ON -
*TENSILE FAILURE, ELEMENT DELETION=YES
[hydrostatic cutoff stress]
*SHEAR FAILURE, ELEMENT DELETION=YES
[equivalent plastic strain at failure]
My question is, how do I determine the hydrostatic cutoff stress parameter from a uni-axial tensile stress-strain data? The equivalent plastic strain at failure can be found as (Total strain - Elastic strain), right?
RE: Abaqus/Explicit: Dynamic failure models
I believe it is the first principal stress at which your material would fail. You could try using the stress from your tensile stress-strain data, assuming your data is given in engineering units, by noting the last point of the stress-strain curve where the derivative changes sign.
More info here
