Liquid Pipeline Pressure drop
Hi all,
Is there a rule of thumb for the maximum pressure drop in a liquid pipeline (psi/100 ft)? I am used to sizing gas plant piping and haven’t done liquid a whole bunch.
Since liquid is an incompressible fluid, I will expect the pressure drop to not be as significant as experienced in gas pipelines. But, what is the rule of thumb when sizing a liquid pipeline?
Any assistance is greatly appreciated.
Sam
RE: Liquid Pipeline Pressure drop
Reasonable pipe velocities depend on the application. There is no correct velocity for all applications. Here is a general guideline.
Reasonable Velocities for the Flow of Water through Pipe:
Boiler Feed.............8 to 15 ft/sec
Pump Suction ............4 to 7 ft/sec
General Service.........4 to 10 ft/sec
City.......................to 7 ft/sec
Transmission Pipelines...3 to 5 ft/sec
Go to a basic hydraulics book. Try Cranes Technical Paper 410 as a reference for the above velocities.
http://www.eng-tips.com/viewthread.cfm?qid=111206
http://www.amazon.com/Fluids-Through-Valves-Fittin...
I am familiar with the velocities. My question is about pressure drop – is there a rule of thumb? 0.1 psi/100 ft? 0.5 psi/100 ft? 1 psi/100 ft?
The fluid velocity sets the pressure drop. Liquids pressure drops are more significant than gas pressure drops. For 3-Inch old steel pipe:
4 ft/sec corresponds to 1.8 psi/100 ft pressure drop
7 ft/sec corresponds to 4.9 psi/100 ft pressure drop
About what size line? 1"? 6"? 24"?
5 ft/sec of water will give about:
6 psi/100 ft in 1" pipe
0.6 psi/100 ft in 6" pipe
0.12 psi/100 ft in 24" pipe
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
See attached "the rules of thumb".
There are no general guidelines on pressure drop - each application is different and requires careful considerations. Different rules apply for gravity lines, pump suction, pump discharge, viscous or non-viscous liquids, etc. Sometimes the process itself requires minimization of pressure drop (e.g. to prevent vaporization of flashing liquid etc.).
See also some of the links below.
http://petroleumcorner.com/line-sizing-criteria-ph...
http://www.cheresources.com/invision/topic/16799-l... (you need to be registered in order to download attachments)
Dejan IVANOVIC
Process Engineer, MSChE
Just for clarification
Pipeline is a long series of Pipes usually of large diameter often underground with few fittings & equipment's mostly Pumps & Valves mainly to control the flow, that are laid with an intention to transport any fluid whether liquid or gas over long distances or cross country.
Piping is a large series & networks of Pipes within the well defined boundaries of the plant/plot with all fittings & equipment's like Pump, Valves, Unions & other Miscellaneous items with an intention to transfer fluid from one facility to another within those boundaries as required
All the aforementioned posts are talking about hydraulics of piping.
Dinesh S SHELATKAR
Process Engineer
Sam,
Is there a rule of thumb - not really as there are too many variables.
As stated before what you get is a range of generally accepted velocities which you turn into pressure drop. Viscosity and temperature has a big impact on pressure drop in liquids so what is acceptable for say gasoline, might no be for heavy fuel oil.
for long distance pipelines, about 1.8 to 2.2 m/sec has proven to be the most economical between larger pipe, lower pressure drop versus smaller pipe,, higher drop. Pressure drops of about 0.5 to 1.0 bar/km would be good for long pipelines (0.2 to 0.4 psi/100')
Shorter lines the economic velocity increases.
The often quoted maximum velocities of 3m/sec and 4.6 (aka 15 ft/sec) are nothing more than guides or a misreading of e.g. API 14E.
Higher liquid velocities and pressure drops often become subject to things like liquid surge effects (aka water hammer), electrical charge etc
Water transmission pipelines typically have a 0.1 psi/100 ft pressure drop.
